How to blackout those par 56 leds. [SOLVED] Topic is solved
triska23
Post by triska23 »
Hi guys, i was creating some fixtures today. All went ok till I tryied some par 56 led with only 3 channels Red/Blue and Green. The only way I know to do blackout is using my dimmer channel as shutter but with only this 3 channel how must i do it?
Thanks in advantage.
Re: How to blackout those par 56 leds.
Post by Jan_K »
When you talk about "Blackout" do you then mean the function open / close shutter or do you mean the "Blackout" button.
If it is the Blackout button you are talking about then Freestyler know that there is only the RGB channels defined and uses them to make blackout.
RGB: ch1=255, ch2=255 and ch3=255.
Blackout: ch1=0, ch2=0 and ch3=0
triska23
Post by triska23 »
well if the scan,par or moving head got shutter i try to do it throught it but if not shutter ill try with dimmer... my question it's how to blackout without those channels.
thanks jan btw :)
Post by Jan_K »
Just define the 3 RGB channel.
Don't define anything else.
Open FS import the fixture and open the "Output" panel.
Set some color on the par can.
If you then press "Black out" then you will that the output on the output panel is set to 0 for the RGB channel.
triska23
Post by triska23 »
It works! thank u a lot bro :)
