I have a new light.
It really does not have a name that I know.
Could be Tint - 5 it is by Rasha Pro Light
I got it from China and I am wondering if anyone has had any success with a fixture file.
I have search for tint 5, rasha, and RGBAW but have not seen anything like this.
Anyone have any idea? I will attach the Manual.
Thanks!
(Side note review on the light)
This light is super bright and well worth the money. A couple will fill any reception hall with massive indirect color flood. Even off a dark wall the color is wicked. I have 12 in the charging case. I just set them on the floor and I have about 8 hours of use. Great investment. I'll even strap them under random tables and when everyone is on the dance floor lite up the table ones and people are amazed.
Tint-5-RGBAW Battery power and wireless par light Topic is solved
djkrazy
Tint-5-RGBAW Battery power and wireless par light.pdf- (889.14 KiB) Downloaded 62 times
djkrazy
Re: Tint-5-RGBAW Battery power and wireless par light
Has anyone played with this fixture file?
I would like a slow rainbow fade but can't figure out the settings for it. Like the one in sound active mode without the beat change.
yoyobenson
I'm working with a DJ doing lighting and he has i believe the same lights you are using. I am wondering if have had problems with the wireless dmx not operating. We address the lights and then it defaults into master slave or color mode have you had any luck? Can you help me out.
djkrazy
I have had issues with the DMX not registering with my network. Its random, when it happens I usually turn the wireless signal off and on and it fixes the problem.
Another scenario is if the unit is just far enough out of reach of the sending unit it will default to the master slave or sound setting.
Let me know if any of that helps.
Sent from my SM-N900T using Tapatalk
Birchy
I have 4 of these lights and I love them - very bright and so much easier to set up (and tear down) than my fully wired lights. One had a motherboard problem, but Rasha were very helpful in sending a replacement & now works great. I have found that using a DMX terminator on the wireless transmitter improves the reliability of receiving the DMX signal. I do see a bit of a difference in mixed colors compared to my ADJ Tri7 and a similar no-name light - I think the Blue is brighter compared to the Red & Green levels - I need to reduce the blue levels slightly to match the magenta color etc.
I have created a fixture file for the 9 channel mode & it seems to work OK. I am a total Freestyler newbie and it may not be perfect. Will upload when I can get onto my laptop & grab a copy.
Birchy
Here is a photo of the lights at a recent gig we did. The Rasha lights are on the floor. The center lights on the tree are the ADJ Tri7's, and the outer 2 are Tornado F5's, which are an e-bay knock off of the Blizzard Fab 5.
Birchy
Here are the fixture files - I had to rename the fixture file as the forum board won't let me upload a file with a .fxt extension.
- Rasha_Tint5_RGBAW_Battery-Wireless.fxt.txt
- (408 Bytes) Downloaded 37 times
- Rasha_Tint5_RGBAW_Battery-Wireless.gif (8 KiB) Viewed 653 times
- Spirit
- FreeStyler Version: 3.5.9
yes thats becouse its the wrongfile..
you need to EXPORT the fixture file so it becomes a .PFF file. (can be found under "FILE")
and a .PFF file is a sort of ZIP file wih everything in it to use it on other pc.
a FXT only contance the Channel info, and not all the other data.
Birchy
Oops
- as I said, total newbie, thanks for pointing me in the right direction. Here is the .pff file:
Rasha_Tint5_RGBAW.pff- (3.52 KiB) Downloaded 56 times
