Android Beta -> Open Invite version 3.0.0.1 Released.
To Join the Beta please join the Google Plus Group Below.
https://plus.google.com/communities/104 ... 2222629266
Once you have joined the Group follow the link bellow to opt in / out
https://play.google.com/apps/testing/uk ... estylerPro
Ensure you have FS version of s at least FreeStyler version 3.5.6. https://www.dropbox.com/s/3gnu2vrn9st9y ... ler512.exe
About the Beta, This is a pre release Beta to test the fetching of labels and status directly from FS.
Pleas leave feedback good and bad regarding layouts and usability.
Will be adding new betas weekly, building up to a stable release.
If you have issues you can opt back out to reinstall the current stable release.
NO SUBMASTERS IN THIS RELEASE, still waiting on a FS upgrade
JOIN THE BETA
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
JOIN THE BETA
