Freestyler universe not appear
- FreeStyler Version: 3.5.5
Hello everyone,
I have a little problem with the last version of freestyler and Magic 3D Easy View. When I click to the button of M3DEV in Freestyler, I have 2 options : ART-net ou SAND-net. No Freestyler.
I think the problem is the new version of Magic 3D Easy View. Is anyone had an older version of M3DEV for playing with Freestyler 3.5.5 ?
Thank you
Thank you
- Spirit
- FreeStyler Version: 3.5.9
Re: Freestyler universe not appear
theres a tutorial how to get 3dview work with FS..
i did it 2 weeks a go and it works fine for me..
Where did you find this tutorial please ?
- FreeStyler Version: None
It sounds like you've not got the correct files in the right place, that's why you can't see the universe. If you've downloaded the new BETA version of 3D easy view, then follow this here to get it working.
viewtopic.php?f=56&t=5579&p=23162#p23162
I followed this tutorial, but nothing new. The Beta version is 14.128.0.410 from 01/28/2014. My freestyler version is 3.5.5.
When I launch the application by c:\SLMEV Beta\EasyView.exe it's okay to open but no freestyler universe.
When I click on 3D button in Freestyler, nothing. Easy view don't start.
- Spirit
then you did something wrong on the tutorial..
and you MUST use the 3d icon on FS to let everything work ok..
In Freestyler log, I have "Object variable or With block variable not set; Easy3d; stop; Line 50"
I didn't something wrong on the tutorial. It's simply to follow it !
I try a lot of things since yesterday to correct this, but no way
There's no way this can't work, because I did a fresh re-install yesterday and I've downloaded the same software. Must be something small that you're missing
I retried 3 installations yesterday, but no good news. When I download a previous version (2011), it works.
I I launch the new version with freestyler, and i open my task tracker on windows, I see a easyview process who appear, and disappear 2 seconds later. It's very strange.
Sure you've got no malware or anything causing the crash?
- FreeStyler Version: 3.5.4
- Twitter: @dijayben
Sorry for double posting but i'm getting the same error after i turned debug on.lhdn92 wrote:In Freestyler log, I have "Object variable or With block variable not set; Easy3d; stop; Line 50"
- FreeStyler Version: 3.5.7
Same here...
Followed instructions but no joy.... Easyview simply wont start from within Freestyler. It does start seperatly but like other users said : no Freestyler universe
using FS 3.5.5 and latest 3D easyview.
I'm wondering if its due to the fact that i selected Virtual interface in FS ? (my physical interface is hopefully 'on route' to my home)
OK , it works now.
I plugged my interface in, put a fixture in FS and now 3D Easyview starts and Freestyler is one of the buttons in the Universe choice windows.
Did some simple color change on a PAR56 and hoera ! We got a visual....
