Freestyler and SeratoDJ
HESCHY
FreeStyler Version: 3.5.5
Post by HESCHY »
Hey @ All
I use SeratoDJ as my DJ software and freestylers for my light show on the same PC when I start SeratoDJ I have no DMX output
a test with an active USB Hub was unsuccessful
I use Freestyler 3.5.5 with a Monacor 512 USB Controller on a Dell Optiplex or Lenovo Thinkpad T400 Notebook Core2Duo 2,66 GHz with 8 GB RAM and Win7 Pro 64bit SP1
any idea ???
greeting HESCHY
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Freestyler and SeratoDJ
Post by Mattotone »
Does freestyler work correctly without serato?
HESCHY
Post by HESCHY »
Works fine...
Gesendet von meinem HTC One X mit Tapatalk
greeting HESCHY
zeller
Post by zeller »
Hello i also try to use serato dj and freestyler 3.5.5 whit velleman k8062 and it´s not possible because if i turn on serato the light go crazy and cant control them, if i turn off serato and unplug and plug usb velleman everything go´s ok.
HESCHY
Post by HESCHY »
zeller wrote:Hello i also try to use serato dj and freestyler 3.5.5 whit velleman k8062 and it´s not possible because if i turn on serato the light go crazy and cant control them, if i turn off serato and unplug and plug usb velleman everything go´s ok.
This is the same problem which concerns me, and I thought my controler works not.
Has anyone experience with the ENTTEC DMX Pro Controler and SeratoDJ?
greeting HESCHY
zeller
Post by zeller »
Hello same problem in here:)))))
Freestyler+ velleman dmx+ serato +pionner cdj sx+ windows7
Return to “DMX Interfaces”
