I can Connet to FS but i didnt see ANYTHING!
No Cues No Cue Lists No Groups ......
Any Sugestions ?
Problem wit Pro APP Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Problem wit Pro APP
Yes, you need to label buttons for the time being.
long click on cuelists and cue buttons.
theres an edit button for the overrides.
I am trying to update the pro app, although i only have about n hour a week to play with it.
- Mattotone
Dev should hopefully be a bit faster as iv managed to finally make my phone connected to my laptop speak via remote desktop to my development machine.
Stefan84
Hi another Problem ore hidden faders?
I am searching in the app the possibility for the faders that are in teh right corner in FS .
I would control the REVO III an found the fixture file here but i cant set some thing becuase
there are no Faders for mode and so on
the same problem is at the martin acrobat i cant set pan an drum rotation becaus there is no fader for it
- Mattotone
The faders are not available due to FS not exposing this functionality in the API.
If you join the BETA program you can use the dmx to midi faders
Stefan84
i dont use a midi device like a key bord
just the pro app and pc keybord shortcuts
- Mattotone
In Freestyler Setup under MIDI control,if you define the DMX channels then the pro app can have control over these channels.
You do not need to have midi or be using midi for this.
- djSupport
Edit you fixture profile to map your acrobat drum rotation channel to something like the beam, focus or iris slider then use that feature within the app.Stefan84 wrote:Hi another Problem ore hidden faders?
Stefan84
@ Mattotone
i looked for teh Midi In but ther is "No input" No Output"
i cant set it to Lop Be internal Midi
AND a friend has the App for I pad and cant connect to FS i entered the IP manually.
No "Autoscan" aviable @ IOS ? have i Open sme Ports on my PC ?
