Linking Sequence's
				Pyros
 - FreeStyler Version: 2.69j
Linking Sequence's
Is there any way to link multiple  sequences so they play one after the other without having to start each one, i have to create a light show for a stage show which lasts about 15 minutes any help with this would be greatly helpfull
 - FreeStyler Version: 4.01
Re: Linking Sequence's
One of the options at the top of the cue window is "loop all sequences". That will do what you want
				Pyros
Sorry im new to this software im running 2.96j and i can not seem to find the button you are on about
				Pyros
okay found it, its just me being stupid
				blaide13
 - Commited FS Forum helper
 - FreeStyler Version: 3.0.1
I found that option to loop all sequences in the Cue menu, but can't get it to work. If anyone has been able to lin k all their sequences in the Cur window and have them play one after another, can you outline the exact proceedure for me as maybe I'm dense, but I'm not getting it and nothing I'm trying seems to work.
I have saved a cue from the menu named "All" and put that into the master cue buttons to the right of the cue screen, but all sequences play at once instead of playing sequentially. I created 7 different chases for 14 Chauvet LED Colorsplash Jr.'s that are mounted in my truss and want to play them in order, not all at once. PLEASE help.
