Blackout if no sound is detected
superdiy
FreeStyler Version: 3.5.5
Post by superdiy »
Is this feature working as intended? I've tried it and none of my fixtures goes into blackout mode when the music stops. I've also selected the Show Output option and monitored the output, but nothing (no channel value) changes when the music stops. When I use the "toggle blackout" option/button in FS my fixtures do go into blackout mode, but not when the music stops. I'm using FS ver 3.5.5 with VDJ and the FS plugin. The fixtures reacts to the music as intended, they obviously also react to the Trigger button in the sound to light window, but when the music stops (even when I close VDJ) the fixtures do not black out, they just freeze in the last state. Any suggestions. Thanks.
pingusso
Just started using FS
FreeStyler Version: 3.6.2
Re: Blackout if no sound is detected
Post by pingusso »
Same for me !
Yep, S2L seems not recognize that "Blackout if no sound is detected"
superdiy
Post by superdiy »
So, can anyone else confirm if it is working or not. I want to log this as a bug then, since I cannot find anything similar under the open bugs.
kittmaster
Commited FS Forum helper
Post by kittmaster »
I have the same issue, it may not be working as expected. Maybe needs to be on the bug tracker.
