LED Strobe - Chinese 6 channel RGB Wash [SOLVED] Topic is solved
twotone12
Post by twotone12 »
Hi All.
I have been trying to setup this 6 channel light on fixture creator.
It is a 6 Channel with values from 1-255.
-Master Dimmer
-Red
-Green
-Blue
-Master Strobe
- 7 Colours choosing
- 2 mixing colours changing
- Colour changing. Slow to fast.
Finally i have some control over it with channel 1 slid across i get Red,Green and Blue and can strobe.
However currently as i sit here it is just staying on green, Even without having any sliders on a value.
When i slide any of Red/green/blue across i get a mix of the green.
How can i disable the green or turn off the led.
Channel 6 runs through all the colours however i can only operate strobe when set at 0.
Any help much appreciated as i have been googling and looking at the forums since last night with no result thus far.
Thanks in Advance.
Kev.
Nathanrs93
FreeStyler Version: None
Re: LED Strobe - Chinese 6 channel RGB Wash
Post by Nathanrs93 »
It can be quite hard without a proper manual, but you could use a 6 channel generic fixture and see if you can create a fixture from that. However, you could use the 6 channel generic fixture to control it. It might be easier
twotone12
Post by twotone12 »
Thanks for reply.
I have nearly full control over it just as soon as i plug in the xlr cable it lights up green and stays that way with all the faders.Meaning i can get other colours but all are mixed with green.
Same with the strobe, It goes to green after each flash.
Will keep changing setting but please post if anyone has any further suggestions.
twotone12
Post by twotone12 »
Fixed - Turns out there was an issue with the casing shorting some wires.
All working perfect now.
