At what version did FS stop working in Windows 2000? Just downloaded the latest version 2.96j and I can't run it on either Windows 2000 machine.
Ken
FS won't run in Windows 2000? Topic is solved
portmanteau
Re: FS won't run in Windows 2000?
worse than that, totally crashed my window 2000 install in a serious way - software hung at startup with flickering progress bar, then blank screen, then BSOD at reboot
this pc has been 99.9% stable for more than 4 years - TILL NOW
Nasty, nasty software!
Crrispy
- Bug Zapper...
- FreeStyler Version: 4.1
'bout time to upgrade
I know, we're all waiting for Windows 7..... but meanwhile XP works fine...
lj_raph
- FreeStyler Developer
- FreeStyler Version: 3.2.1
Please guys search the forum or read some earlier topics before you start a new topic.
In an earlier topic the problem has been discussed.
A solution will available in the next release.
Best regards
Raph
Best regards
Raph
Raphaël
