Helo!
Stairville AFH-600 DMX Hazer
MOMO17
AFH-600 Hazer.pff- Stairville AFH 600 DMX Haze). Powerful hazer with great features such as very low heating time and adjustable thomann fog density output. The AFH-600 is suitable for medium-sized theaters, clubs, discos, etc. The built-in DMX512 interface also enables control over any, commercial DMX controller. Through the various Stairville fog fluids available this allows the AFH-600 to produce nearly all required denstiy thomann of haze . Specifications: Heating element: Electronic evaporator with 600 W, warm-up time: 2 min, tank capacity. 2.3 l, incl DMX-512 (1 channel), DMX input and output: 3-pin XLR power supply: AC 230V, 50 Hz, max. Power consumption: 600 watts Dimensions: (LxWxH) thomann 450 x 290 x 265 mm, Weight: 5,5 kg, This machine is intended for use exclusively original Stairville fluids. FAST FOG (209 054), EM Fluid (121307), E Fluid (105454), EC fluid (105455), e-Heay HD Fluid (105456), please do not use any kind of smoke thomann oil,
- (2.03 KiB) Downloaded 182 times
