Programming sequences... Topic is solved
kjacobs
Post by kjacobs »
Does anyone know if there is a way to program a sequence so that it can be manually triggered only? I want to be able to start a sequence in the cue page and have the first scene come up and then manually trigger through each step without the sequence running automatically with the time programmed. Or...do I need to make each scene as a separate 1 step sequence and then page through them on the cue?
