assign keyboard key to specific dmx adress Topic is solved
angus
hi. im using freestyler to control a dmx relay board that runs a flamethrower. i have 8 of them and will be running sequences through freestyler but also want to use the keyboard to activate the 8 flamethrowers so users can have a play with them. im using version 3.4.6 as my usb to dmx is not compatible with the most up to date version. is it possible to control a specific dmx address with a keyboard key? thanks
- Spirit
- FreeStyler Version: 3.5.9
Re: assign keyboard key to specific dmx adress
No this isnt possible.
BUT! you can use the override buttons to do the job.
make 8, 1step Full on Sequences.
and put them on 8 differnt override buttons.
and assigne a Keyboard key to the override button.
PS: set the override buttons to FLASH, so they will only light up if the button is pressed.
angus
Thanks. Ive been mega busy and just checked in. As soon as the rest of my hardware turns up its game on.
angus
thanks again. this works perfectly. if i ever meet you i owe you a beer.
