CHAUVET Q-SPOT 260 LED
- FreeStyler Version: 3.5.5
I have four of these moving head CHAUVET Q-SPOT 260 LED and I can't find it on FREESTYLER fixture list.
how can I add and/or make one. I am pretty new to this whole computer dmx program.
can someone please show me the TUTORIAL LINK to add a fixture that are not on the FS preloaded list.
thank you,
Pinoycanadian
thank you,
Pinoycanadian
- FreeStyler Version: None
Re: CHAUVET Q-SPOT 260 LED
Hi there
There is some info about starting out with things on the wiki: http://www.freestylersupport.com/wiki/welcome
You should be able to find what you are looking for there
Any questions, just reply and I'll help you out with anything
Peace
Peace
is there anyone here that has already pre-made for chauvet q-spot 260 led?
- FreeStyler Version: Beta
ok. I search in my computer.
My Computer/C: /freestyler/scan library/chauvet/qspot260led.ssl2
I can see my chauvet q-spot 260 BUT it is not on FREESTYLER FIXTURE FOLDER
on FREESTYLER FOLDER/SCAN LIBRARY/ I CAN SEE THE Q SPOT 260LED.SSL2
on FREESTYLER FOLDER/FIXTURES/ IT'S NOT SHOWING THE Q SPOT LED260
And when I go and open my freestyler program then add fixture, then Chauvet...I will not see the model of my light.
Hey there
It will not show up because SSL.2 is the file extension for 3D view not Freestyler. It's a different extension because they aren't done by the same developer, it's just that FS has protocol to use 3D view. If you are talking about Freestyler fixtures then it will be in the file extension of .FXT
Here is the fixture file, click and it will install automatically
Re: CHAUVET Q-SPOT 260 LED [SOLVED]
this is awesome. do you have one for CHAUVET Q-ROLL 250?
unless of course Q-Scan 250.pff are the same?
I can't find it either on CHAUVET FILE FOLDER. thank you.
I wouldn't have thought there would be much difference apart from mirrors. If you want you could try it and find out if it works, otherwise you'll need a fixture creating for it.
the strobe part is missing.
In regards to the Q-Spot 260 LED fixture? It doesn't appear to be because I've just installed it myself?pinoycanadian wrote:the strobe part is missing.
Sorry. I was quoting my other lights the Q-ROLL 250 that the strobe portion is missing.pinoycanadian wrote:this is awesome. do you have one for CHAUVET Q-ROLL 250?
