I created the profile but it seems like channel 1 is causing the issue. Can someone look at this and tell me where I went wrong. I will not control the light at all. here is the manual http://www.omezlighting.com/manual/OM103.pdf and I will upload the file :
Thank you in advance....
Need help with Omez Floodpar38 [SOLVED] Topic is solved
jdthedj10
Omez Flood Par 38 4ch.pff- (3.25 KiB) Downloaded 28 times
- FreeStyler Version: Beta
Re: Need help with Omez Floodpar38
The PDF you link to is a High Tech Lighting par.
Channal 1 has to be used as shutter and dimmer. There are a some tutorials on the wiki that will guide you step by step.
I have modified and renamed your fixture. have a look.
