Hi all,
Is there an API and/or methodology for developing FS Add-Ins or Plug-ins or whatever you want to call them, essentially allowing third-party control? Don't care what language it might be in.
Thanks!
Kendell
API for FS add-ins? [SOLVED]
kwelch007
- FreeStyler Version: 3.5.6
- I Use FreeStyler for: Band
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: API for FS add-ins?
yes, a quick search for sendmessage should bring up my dll file for basic coms with FS.
theres a tcp/ipguide in the FS directory
kwelch007
Cool. Thanks! Well documented even
