problem with compatible entec/usb dongle
marcocelina
Post by marcocelina »
Hello,
my problem :
when i make all my par 64rgbw at same adress, no probl. when i make specific adress (8ch/per inch), i test one by one, it is ok, but if i use 2 or 3 in same time... bug... all take the same function ! also the mini kinta ! i don't know if it is freestyler bug or dongle dmx bug ?? i have a BIG problem ! i test give extrem adress :
par 1 : 0-8, par2 20-28, mini kinta 40-43. it is the same problem after test !
anyone can help me please ???
a french men in a little school of music...little money... :roll:
Nathanrs93
FreeStyler Version: None
Re: problem with compatible entec/usb dongle
Post by Nathanrs93 »
Try updating your drivers for your interface
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Also make sure you have the correct modes and profiles loaded for each light. :) To test when you select fixture open the attribute windows for colours and make sure that you are getting the colours that you are meant to when you when you click the colour button. :)
Return to “DMX Interfaces”
