How can I Change direction in Shapes? [SOLVED]
Goochie
FreeStyler Version: 3.5.5
Post by Goochie »
When using one of the shapes, e.g. Circle, I can have two heads on two different circles in same step, one on a large circle other on a small circle for example, but what I would like to do is have one head going 'Clockwise' and the other going 'Anti-Clockwise' Is this possible and if so how?
In other words how can I change the direction of just one Head?
Thanks in advance.
Goochie.
Re: How can I Change direction in Shapes?
Post by Jan_K »
Try the FlipY function.
Goochie
Post by Goochie »
Thanks Jan,
tried that doesn't work.
Post by Jan_K »
Any of the two flip functions will reverse the movement and I normally uses flipY
what does the flip do to your fixture
Goochie
Post by Goochie »
It changes location of beams, say from front of stage to back, or from floor to ceiling. Hope you understand?
All I want to do is change the direction of travel from Anti clockwise to Clockwise.
I have even tried to rotate shape but that doesnt work.
Post by Jan_K »
Rotation makes a delayed movements.
I will have a closer look on what they are doing when I uses flip.
Goochie
Post by Goochie »
Many Thanks Jan.
very frustrated here! ha ha
Post by Jan_K »
Think you are to flip both.
Goochie
Post by Goochie »
JAN,
Think I've found it here....
http://www.freestylersupport.com/wiki/f ... zier_shape
I think this is what you were talking about, sorry I didn't understand.
Just going to swith lights on now and try this out.... Watch this space....
Post by Jan_K »
Look out that info is 2 minutes old.
I just added it. :D
Goochie
Post by Goochie »
YES YES YES, Done it Jan!
Many thanks.
