Help Needed (Chauvet Wash LED 150) [SOLVED] Topic is solved
youngkwangk
Post by youngkwangk »
Manual is here (http://www.chauvetlighting.com/products ... _ML_WO.pdf)
I have attached what I have.
Here's the problem I am having.
Everything works well. but when I try to use Master Intensity (and Fade In & Fade Out)
the intensity channel does not do anything.
It might be because the intensity value goes from 134 to 8. but that's the only way it makes it work with dimmer control from the Lamp window.
Here's what I have tried.
* channel inverse feature, but no luck from that either.
* putting it into submaster and control intensity from there (does nothing)
Can someone help me, please?
Intimidator Wash LED 150.pff
(11.22 KiB) Downloaded 32 times
Nathanrs93
FreeStyler Version: None
Re: Help Needed (Chauvet Wash LED 150)
Post by Nathanrs93 »
Here
UNTESTED!
(78.93 KiB) Downloaded 35 times
