Chauvet Intimidator Spot 100 IRC [SOLVED] Topic is solved
yoshi-D
I've been looking all over for the Intimidator Spot 100 IRC. I just got two of them and have tried to use the 250 file with it but it will not function right... If anyone has it please let me know...
billybob132
Re: Chauvet Intimidator Spot 100 IRC
Just found this thread. I am looking for the same thing.
Did you have any luck?
billybob132
I have started writing my own but it is not going well.
How do you create folder tabs, i.e. for control
after doing edits of color wheel all the original stuff reappear. How do I delete them.
Sorry, I'm a newbie.
yoshi-D
I'm still new and have been trying to make one as well... I don't get why there is not one out there yet there such good lights.
yoshi-D
I have not got all the kinks out of it but this should function till I finish it. Seems that the only issues are the gobos are not the right pictures, one of the color pictures is not right and the strobe values need to be adjusted. I will try to get a better one up soon but its a start.
Intimidator Spot 100 TEST.zip- (746 Bytes) Downloaded 101 times
- FreeStyler Version: Beta
Hej Yoshi
You are well started.
When you have a fixture you want to upload then use the "Export" function.
It generates a pff file. The fxt file don't contains images and so on. The pff does.
yoshi-D
Sorry about there here is the export
Intimidator Spot 100a.pff- (124.38 KiB) Downloaded 170 times
