Problems transferring onto new pc [Solved] Topic is solved
David_l_perry
Post by David_l_perry »
Just installed freestyler on a new laptop as the original machine is getting a bit long in the tooth and we want to have a full functioning backup if it stops working
Freestyler is up and running and I have transferred all the fixtures and scenes.
It opens up and shows all the fixtures as they should be, and has all the cues and buttons exactly as the old laptop. Thats all looking good
Howevor all of the cues open up as running as soon as I select a cue list and I cant seem to change it
Any body explain what I need to do to remedy this or what I may have done wrong - its possibly that there are other files I have not transferred over ??
Many thanks
Dave
David_l_perry
Re: Problems transferring onto new pc
Sorted it -
Just need to change the options on the cue list
1) Open freestyler as normal
2) Click on the ‘Cue’ button to open the cue list with all the set
3) Click on the settings wheel directly above the button
4) Tick ‘Load Cue Only’ and deselect anything else that may be selected
Worked for me.....
