Stairville Par Led 64 MK2 RGBW 10mm SI
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Film
Good evening, I purchased the par 64 of the RGBW Stairville MK2 10mm YES, I would like to know if there is a fixture for the freestylers, if there is how do you create? can you help? thanks
- FreeStyler Version: None
Re: Stairville Par Led 64 MK2 RGBW 10mm SI
Hi
You can create fixtures if you need to by using fixture creator in the freestyler folder, in the start menu. If you need some help then upload what you've done and one of us can point you in the right direction. If you wish you can request it here, but there's no guarantee it will be made for you as we encourage to try yourself so you have a better understanding of things.
Peace
Peace
I'll explain, I downloaded the fixture for Stairville LED Par 64 10mm IS MK2 RGBA believing that you hang together, my problem is that in the creation of the fixture with the option includes the RBG color ALO, and there is the color white, how can I do? I also saw that in the instruction manual setting dmx 8 channel RGBA is different ....
- FreeStyler Version: Beta
Hej
I just had a quick look in the manuals
The only difference I found is that channel 4 is white (RGBW) or amber (RGBA).
So you just have open Fixture Creator and remove the amber channel.
You then have to add the white channel 4 to WW or CW.
thanks for the advice!
then I just have to change that setting, and leave all the settings the same.
I have the fixture of RGBA, change only the color and everything else I leave it the same?
Yeps!
And when you have changed it then "Export" it and upload the file here.
thanks!!! ok ok XD
Hello, I created the file, I have not tested it yet, but I think it works, you can see it to tell me if there is something wrong?
thanks
thanks
It looks right.
But you have to export if to pff format.
The fxt you have uploaded don't have all information included
here is formatted pff
Hello everyone, just a short put the file changed, initially I worked the strobe, and the various effects of changing colors automatically, now everything seems to work! almost everything!
I have a problem, when I put the par together with scanners djsca250xt of stuff I can not get to play the scanners automatically, why?
You don't need to pack it into "rar".
pff files can be uploaded direct. fxt can't
I put the following file almost complete, I placed the strobe was not working previously.
I can not get to make two independent programs with one scanner and one at the par why?
I am not sure what you mean by programming but I guess that you mean creating sequences and playing them back in a cue.
If so then here are an example from the wiki
http://www.freestylersupport.com/wiki/t ... playground
