Can I use two dongles.
Gordonmoore1
I need to upgrade our lighting system from a very basic 8 channel incandescent system. Due to our physical setup, we have two dmx cables leading out from the sound booth. Can I use two dongles on a single computer and control the lights with a single instance of Freestyle?
Nathanrs93
- FreeStyler Version: None
Re: Can I use two dongles.
Nope. I'm afraid FS only supports one interface at the moment, so this isn't possible. However, you can run two interfaces from two separate computers otherwise you'll need better software.
Peace
Peace
- Spirit
- FreeStyler Version: 3.5.9
hi you can also use a DMX spliiter to split 1 dmx cable to More..
