Martin Destroyer X250 V2
Merril
The built-in Martin Destroyer X250 did not match the fixtures I have, so I created new profiles for both Freestyler and Easyview3D. I didn't want to wipe out someone else's work, so I created a "v2" profile. It is still not completely accurate, because I was unable to get certain configurations to work with EasyView3D. I had to remove a couple parameters in both profiles to get the proper gobos and rotation to work between them. I will continue to work on it, and if I can improve it, I will post again. This version (V2) is much more accurate than the the current profile for Destoryer X250.
Destroyer X250 V2.pff- This is the Freestyler profile to import.
- (44.34 KiB) Downloaded 8 times
DESTROYER X250.ssl2- This is the EasyView3D profile
- (11.7 KiB) Downloaded 5 times
Nathanrs93
- FreeStyler Version: None
Re: Martin Destroyer X250 V2
Here for 3D files: Click Me
Merril
I updated this one to include macros and changed a couple channels to gobo channels for better control.
I still can't get both gobo rotation and wheel rotation to occur in easyview3D automatically (via the "random" values), but otherwise this seems to work. I will post the 3D file in that forum topic (later).
Destroyer X250 V2.pff- (99.47 KiB) Downloaded 17 times
- beefy-stu
- FreeStyler Version: 3.5.5
- Twitter: https://www.facebook.com/deconomix/photos_albums
Good Job Merril,
I was going to create this myself, hopefully it will be included as the correct fixture including gobos soon. Locally I did tinker with the values for slowest rotation to 91 and 99 respectively to have a more noticeable difference between fast/Med and slow. How is the 3D file working out?
Diagnosing my way, one cable at a time.
Merril
I made some more adjustments myself. I was having some stability issue with the latest version of freestyler and Easyview3D, but put 3D into windows7 compatibility mode and it seemed to help. Now I am able to tweak settings without Freestyler crashing on me. I'm not going to keep posting minor updates, but will if I make any major changes. I'll check to be sure the 3D file is in that topic.
