Hi All,
I have had a look here: http://www.freestylersupport.com/wiki/t ... e_tutorial
And here: http://www.freestylersupport.com/wiki/f ... zier_shape
But unfortunately cannot see what I am after.
Could anyone please explain exactly what the Yellow, Blue and Red coord points for adjusting the shapes using a mouse mean.
Thanks in advance as always.
Bezier Shapes Adjustment [SOLVED]
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
kittmaster
- Commited FS Forum helper
- FreeStyler Version: 3.6.2
Re: Bezier Shapes Adjustment
I never understood the colors either, but doesn't seem to matter, the shape that you draw seems to be the shape the fixtures tend to follow.
I'd also like a little clarification of this also if anyone has it.
Regards,
Chris
Regards,
Chris
- Uriahdemon
So not such a daft question...... thankful for that
Mac
www.mclite.co.uk
www.mclite.co.uk
kittmaster
It's a great program and there are many things that are not quite explained but sure works damn good. No such thing a daft/dumb question, I'm sure others would like to know as well.
- Spirit
- FreeStyler Version: 3.5.9
this is realy easy..
you have the:
yellow block = Start Corner
Red block = next concers
Blue block = is to adjust the corner to a Sharp point or to make a a Realy nice Smooth circle..
and you can adjust each corner seperate..
so each RED/YELLOW bloch has 2 Blue blocks...
you have the:
kittmaster
Yes I see now also, thanks for the feedback spirit, I never really had to mess around with the shapes yet because I just cascade the prebuilts ones together which is more than adequate for my needs.
Hopefully this will help others.
- Uriahdemon
