Based on some of the stuff in the wiki, I've got my head around some of the submaster use and got some presets. Questions I have now are:
- can I add more than 20 sequences to a cuelist? One of them (my LED bars) I'd rather have 30 presets (one channel that does the 7 RGB colour options then the onboard programs)
- the Intensity fader for some submasters doesn't seem to control the Dimmer channels (set as Intensity channels in the Fixture profile), i.e. my Strobe presets listen to the submaster fader for their Dimmer value but the QColour (LED flood) ones don't
A couple of niggling queries [SOLVED]
worldofdavep
- FreeStyler Version: 3.5.2
- Twitter: http://www.twitter.com/worldofdavep
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
Re: A couple of niggling queries
Hi, I am afraid you cannot use any more than 20 Sequences per Q list at this time. You could make the additional Q's up and assign them to a cue list button.
On your second question, there could be many things wrong here but to check the basics first. Is the fixture file correct, (although there are many good and operable fixture files there are a few that require some tweaking), is there a setting on your fixture that is not set properly, and I see you are operating this on the SM's therefore have you built the cue you assigned to the SM properly...??
Mac
www.mclite.co.uk
www.mclite.co.uk
