Joystic, gamepad or arrows
Karo88
LJ
FreeStyler Version: 3.6.50
Post by Karo88 »
Joystick for stepless adjustment or movement arrows
Control Pan / Tilt movement, set position and get the device, adjust the speed Pan / Tilt movement, especially in the use of balls and weddings.
Tested Win8 64bit, Win7 32bit
UPDATE 2014-01-01
joystick.zip
(55.7 KiB) Downloaded 778 times
Cri95
Re: Joystic, gamepad or arrows
Post by Cri95 »
Hi, how I can connect this tool to freestyler?
toob
Post by toob »
Can this be made to save and restore values when exe is next used? For example pan/tilt setting and speed and selection, ie remember Joystick (XY & YR)
Don't bother, ive added these and other features myself.
brad_68
Post by brad_68 »
Will you share your new and improved fixture?
Melvilh
FreeStyler Version: 4.1.1
I Use FreeStyler for: Theater
Post by Melvilh »
Bonjour cette aplication a besoin d'etre au premier plan pour fonctionnner avez vous une solution?
