Hi there i am new in this Forum and i have got a Little question
I want to use ev3d beta with the new fs 3.5.5 but it. doesn't work.
I installed the new Version of fs with the 3D ev and Then i tryed to Start ev3d in freestyler but nothing Happend. The program only opens up when i Start it from the desktop.
Either i tryed to install the beta Version of m3dev like you discriped in this Forum and it doesn t work
Can someone help me
3.5.5
Nathanrs93
- FreeStyler Version: None
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
Re: 3.5.5
Hi Nathanars93,
I have the same problem for V3.5.5 and have done this fix a number of times for previous versions. The difference here is that I have always only replaced the EasyView.exe file from the Magic 3D Easy View beta folder to the FS folder and all worked.
Unfortunately within the SLMV file on the C: drive I dont see the file MEVP.zip so cannot replace that. Will that make a difference and if so can you help me with locating it please.
I am keen to use the 3.5.5 version as I use a touch screen and having all cue lists on the same page would be a god send.
Thanks in advance as always.
Mac
www.mclite.co.uk
www.mclite.co.uk
Nathanrs93
Re: 3.5.5
HeyUriahdemon wrote:Hi Nathanars93,
The MEVP.zip should be in the download folder of the BETA version, but if it's working for you just by copying the .exe file then why are you asking about the zip folder? The zip folder I believe was for the previous version but if it works just by copying the .exe then do that because in theory the zip folder should already be unzipped from last time if you've not messed with any other files other than .exe
Understand?
I don't understand how it's not working for you because I have the 3.5.5 version and it works perfectly?
- Uriahdemon
Re: 3.5.5
Yip, I have replaced the .exe file but still no joy. I was wondering if because i couldnt replace the zip file if that was the issue but seems not.
Think its time for an uninstall and start over again.
Mac
www.mclite.co.uk
www.mclite.co.uk
Nathanrs93
Re: 3.5.5
It could be the zip folder causing it because it has files in there, that are needed for FS. But probably better like you say to start over again so at least you'll know for next time.Uriahdemon wrote:Yip, I have replaced the .exe file but still no joy. I was wondering if because i couldnt replace the zip file if that was the issue but seems not.
