I've noticed when I have a chase with say 7 scenes in it with the scene time set at 5 Seconds, and I then set it to "random" in the cue list, it sometimes seems to stick on one cue for say 10 seconds, I think what is happening is that it is randomly selecting the same scene twice in a row. Just wondering if its possible to alter this behaviour so that the scenes are only repeated once all 7 scenes have been shown? (The CD Player in my car has a similar NON-RANDOM feature and it plays the same song twice before having played all songs on the CD! Very Annoying, especially when they come on twice in a row!) .. Anyway, thought I'd point it out, like I say not a bug as such just a minor annoyance.
Guess a simple way round it would be to have a small 15 Element array and store a value like "0" in all as the random pattern starts. Then as each Scene comes up change it to "1", then if the random scene chosen already has a 1 in the array, pick another value till all are used then 0 them all and start again. (Hope that makes sense!)
Cheers
Plasma
Not a bug as such .......
YOU MUST FILE A BUG REPORT HERE before discussing possible bugs.
