QTX QUATROSCAN & CHAUVET MEGAMOON [SOLVED] Topic is solved
lemon2007lemon
Post by lemon2007lemon »
Hello all...
I have been trying like crazy to create fixture setting files for the QuatroScan and MegaMoon with no luck whatsoever.
Could anyone please help...
Thank you!
Re: QTX QUATROSCAN & CHAUVET MEGAMOON
hi
please upload your .PFF (go to FILE and press EXPORT)
so i can take a look at your fixture files and i can also say what you did wrong..
also please add the links to the PDF files..
lemon2007lemon
well....... i dont think i really have anything of any use saved to the pff as nothing works at all
i would say try again if it still not works, upload the .PFF
also dont forget the PDF files ;)
lemon2007lemon
hi again well this is as far as i got...
1MegaMoon.pff
(2.42 KiB) Downloaded 58 times
Mega_Moon_UM_Rev01b.pdf
(698.21 KiB) Downloaded 82 times
im sooooooooooooo new to this, i think if someone could show me a completed file for this i could work it out.
thank you!!!
uhmm yes i see the issue. as you only filled in the Srobe channel but still i agree this fixture is a Pain in the @$$ to create...
i will try to make it but dont think it will be ready soon, as these days i'm realy busy.
but still you can use the sliders on the Right side of Freestyler drag Slider 1 to 4 up and you should see light.
lemon2007lemon
thank you very much... i would really appreciate any help you could give me...
time is no issue,lol
thank you and all the best!!!
lemon2007lemon
Hi all,
Did anyone get anywhere with this?
Thanks in advance
oww oeps sorry totaly forgot you but.
it seems this fixture file is allready made :D
as i search for the tutorial how to make a Fixture with 4 differnt segments with the same features.
i noticed the fixture used on the tutorial has the same DMX chart as your fixture ;)
so look at this page so you understand how the fixture file works:
http://www.freestylersupport.com/wiki/f ... plications
and offcourse download the CHAUVET4PLAY fixture and everything should work perfect.
