I am working on a fixture file.
i have the manual, and I have correctly entered everything in.
My file works perfectly.
BUT
The light has built in two built in auto modes. but no mention of them in the Manual. Do they only exist in the fixture (hardware) but not in the DMX Channels?
it's a 14ch moving head. could these be hidden in channel 15 or more?
I am intentionally not posting my fixture file as it is not totally complete.
If you must know this is a eBay China light - 60W Spot Moving Head
Yes I am aware this fixture file already exits, but it is not complete or the same light as mine, I tried that file. Nor is it the clone of the Q-Spot 260 LED it also lacks some functions. Once I figure out the Auto functions, ill post the file.
Thanks for any ideas on the AUTO modes
Hidden channel ? [SOLVED] Topic is solved
- FreeStyler Version: Beta
Re: Hidden channel ?
You can change the total number of channels to 15 or 16 and then try to use the faders in right side of FreeStyler to see if this change anything.
You are in a try and error process.
