'Auto' Cuelist Button Playback - The Cheats Way [SOLVED]
Kings
Commited FS Forum helper
Post by Kings »
OK, so you want to walk away from FS (toilet break?) but still want your light show to continue...but change periodically.
1) Choose or create 6 different looks that you like that can be assigned to a cuelist button.
2) Create 6 different tabs of cuelist buttons.
3) Add each of your favourite looks to the first cuelist button of each cuelist tab
4) Now open up FS external control and pick a key on your keyboard (lets say the key 'a') and assign it to both 'next cuelist tab' and 'toggle cuelist one' (YES! you can use the one key for two different actions).
5) Download the following bit of software:
http://installation.murgee.com/auto-key ... nstall.htm
What this program does is automatically press a designated key after a preset amount of time. Set the software to press 'a' after say 30 seconds.
So...
Every 30 seconds, FS will swap cuelist tabs AND start the cuelist in the first cuelist button. You can now enjoy that toilet break knowing that your show will continue without you!
Re: 'Auto' Cuelist Button Playback - The Cheats Way
Or you can download one of the remote apps and while your having a shit whack on the strobe, flash your pars and change your looks :)
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
so elegantly put Adam lol
It is a simple solution, one i have never come up with myself.
Plus there's GoMonkey for complete automation.
Matt
Kings
Post by Kings »
I've already subtitled 'auto pilot' as a feature request but I might as well ask for a 'next cuelist button' keyboard shortcut now that we can automate it ourselves. Still would be nice if we could get it to change every 4, 8, 16 or 32 beats.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
I use Ableton Live to do all that. :)
Kings
Post by Kings »
Ahh...so the software I mentioned in the OP allows you to have multiple instances running. So it can 'press' multiple keyboard buttons after a selected time. I'll have to experiment with this.
