Could slow response in FS be my interface (Velleman)
lindsayward
Post by lindsayward »
Hi.
I was looking at USB-DMX interfaces recently and discovered that some provide DMX timing on board (pro), while others rely on the software/PC (open). I'd like to know if upgrading my Velleman K8062 interface to something "pro" (like ultraDMX RDM Pro http://www.dmxking.com/usbdmx/ultradmxrdmpro) might improve FreeStyler's performance.
In particular, when I tap tempo for my LED lights, it's never quite the same. I have to tap faster than the beat to have it go as fast as I want. This could be a setup issue (fades?), but maybe the interface could be part of it.
We sometimes have to unplug and reconnect the Velleman interface to get it to work, so I'd like something a bit more robust.
Thanks!
BillsGate
FreeStyler Version: 4.x
Re: Could slow response in FS be my interface (Velleman)
Post by BillsGate »
That definately sounds like a Vellemann-issue. I have bought several of them in the past and lately I'm replacing them by Enttec Pro's and Art-NET devices. The difference is amazing!
With a Vellemann, using tap-sync will result in slightly off-beat steps. There's a delay in pressing override buttons aswel. And strobing with some led fixtures or pan/tilt moving is just disastrous if you use more than 96 dmx channels.
Try to borrow a more pro interface from a colleague and find out for yourself.
Return to “DMX Interfaces”
