Hello to all,
I'm new, and are therefore to seek help.
I have in my theater TECLUMEN 4 headlights, exactly these:
http://www.teclumen.it/index.php?page=s ... &Itemid=52
Someone would know to help me in the creation of the fixture.
In particular, I can not use the FADE.
Thank you very much.
Teclumen Help
SimoBS
- FreeStyler Version: 3.5.5
- FreeStyler Version: Beta
Re: Teclumen Help
Hej SimoBS
You can wait for ever on this fixture unless someone has it on his PC.
But there are a lot of tutorial about creating fixtures so you can easily create the fixture your self.
This is on a moving head.
http://www.freestylersupport.com/wiki/f ... oving_head
In general have a look here.
http://www.freestylersupport.com/wiki/fixture_creator
http://www.freestylersupport.com/wiki/f ... eator_help
If you need help then ask and I will guide you.
SimoBS
Re: Teclumen Help
I tried to follow the guide, but the stage still does not want to work ..
all other functions ok ... But the Fade does not want to work!
Re: Teclumen Help
Hej
I need a bit more information.
What do you mean when you write "stage" and "Fade".
Also "Export" the fixture in "Fixture Creator" and upload it here.
SimoBS
Re: Teclumen Help
Ok, after I try to load the fixture ..
Fade, I mean the progressive lighting of the lighthouse .. Stage is a mistake ..!
Re: Teclumen Help
Sorry still a bit lost in what is failing.
Is it the fixture control.
