Korg Nanopad2 and Freestyler Topic is solved
kenstechauner
Post by kenstechauner »
Help! I can map functions to notes, but it does not work. I am sure I am missing something. I want to start the sequences I have n a cue. In the midi control setup, for example, I click "Start Sequence 1" and I tap a pad on the Korg and the Midi channel populates.
When I try to use it it does not work. What am I missing?
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Korg Nanopad2 and Freestyler
Post by buttza »
make sure you go to
setup=>freestyler setup=>external control=> midi control
make sure that the input device is set to the Nanopad and that you have clicked start. Now save and reopen freestyler. Should be working. :)
oebb
Post by oebb »
Restart of FS did the trick for me ;)
Kings
Commited FS Forum helper
Post by Kings »
Search the forum for the following 'setting up a Korg nano' and find the tutorial I posted.
federicomonzon
Post by federicomonzon »
hola: alguien posee un listado de los controladores midi que se pueden usar con freestyler? donde se puede descar los drivers?
muchas gracias...saludos
sonicdj
Post by sonicdj »
I am getting the same issue. I tried the steps above, but the software is different now.
