mac 250 v1 dmx4
platini76
mac 250 v1 dmx4
Post by platini76 »
I have 4 martin mac 250 and in mode 4 they have 13 channels
how can I use them in mode 4 in freestyler?
the only fixture I found is 11 channels...
thanks for help.
Re: mac 250 v1 dmx4
Post by Jan_K »
I just had a fast look on the DMX table in the user manual.
The Mac250+ fixture is the DMX 2 mode so you just add the functionality for channel 12 and 13 then you are in DMX 4 mode.
But I think that I would run them in DMX 2 mode if I had to use them.
The difference between mode 2 and 4 is Pan Tilt Speed. Can't remember when I have used that function.
It is always running at max.
And the "Effect speed" It will normal be in tracking mode.
So I don't think you miss anything by running them in DMX 2 mode.
But if you want to create the DMX 4 mode then try modifying the MAC250 + fixture and if you need help then just ask and I will try to help you.
Geert1903
FreeStyler Version: 3
Re: mac 250 v1 dmx4
Post by Geert1903 »
does anyone have martin mac 250 m4 file?
