I have a problem with the 3D. Every time i create new stage and save it, it won't open next time. Default empty stage open every time when i try to open some of my own stages. And every time i open 3D, that "default" stage will open.. why?? It's useless to create anything if those aren't able to use later
Problem!! Stage saving
Nathanrs93
- FreeStyler Version: None
Re: Problem!! Stage saving
What is your setup and where are you saving it? Do you have the BETA version? Explain
PeetuXD
Setup? You mean what i have created there? Different kind of things, objects, fixtures, etc... tried to do different setups. I have tried to save it to different places... no help.
I have version 3.5.4 Freestyler. 3D is version 12.827.3539.0 BETA
Nathanrs93
Hmm, it's quite strange as I have no problem saving myself. Have you tried un-installing 3D view and re-installing? Same with FS? Possibly update to the latest version of FS (3.5.5)
- buttza
- FreeStyler Version: 3.6.4
Are they being saved to FS folder or the SLMEV Beta Folder?
When you save sometimes you have click User Mode first then Save.
Sometimes it wont save in Construction Mode.
Also update both applications.
Nathanrs93
Good point, buttza. But it should save in FS if your running 3D view through FS, if not then it can change the location where it saves it. It's normally the BETA folder like you say, but I made a mistake once by opening the original version of 3D view and didn't realise so I was panicking when I thought I lost my file
