Cant find my led Topic is solved
maxz
Cant find my led
Post by maxz »
I cant find the right configuration for my led. These are the ones i have...
http://www.jaycar.co.nz/productView.asp ... rm=KEYWORD
But every par 64 led i try doesnt work. What do i do?? i found one that has six channels but all it does when you try change colour or brightness is it strobes. Please help
Nathanrs93
FreeStyler Version: None
Re: Cant find my led
Post by Nathanrs93 »
If you can't find your fixture then be sure to request it here : viewforum.php?f=79
It might be quicker and better for yourself, if you build it using fixture creator.
You'll need the manual with the DMX chart to build the correct fixture for it properly, if you don't have it then it can be highly difficult to build it. Be sure to check here as well for new releases that come out ever month for fixtures: viewtopic.php?f=23&t=4528
Need any help then give us a shout :)
maxz
Post by maxz »
Thanks!
