HOLLYWOOD Strobe 1500 DMX
Marvo2011
Post by Marvo2011 »
Hello,
I have a Hollywood Strobe 1500 DMX risen unfortunately it made some problems and I had to create a separate fixture.
The stroboscope only works if the start address is set to 1. Then it takes 3 DMX channels.
1 Channel: Strobe
2 Channel: Strobe
3 Channel: Dimmer
Channel 1 and 2 must always be identical so that the strobe runs smoothly.
To make this easier, I created macros. (All images are from the original fixture freestylers folder.)
Hope it can help someone. It does not have the error occurs also with you. However, I have discovered a similar problem with reviews.
Strobe 1500.pff
(41.67 KiB) Downloaded 136 times
Nathanrs93
FreeStyler Version: None
Re: HOLLYWOOD Strobe 1500 DMX
Post by Nathanrs93 »
Thanks for the contributing Marvo :) It's never easier creating fixtures as I remember it was like a puzzle making my first one :lol: Keep up the good work :fs:
Kings
Commited FS Forum helper
Post by Kings »
Wow...I've had the same trouble with some cheap Chinese strobes with dodgy DMX but never thought to add the extra channel. Good find!
flashbeforemyeye
FreeStyler Version: 3.6.51
Post by flashbeforemyeye »
Thank you very much!!!!!!! I had been trying so hard to find a solution and finally your workaround fixed my Astrolite Strobe. I configured the 3 channel fixture (strobe, strobe, dimmer), set up in DMX address n°1 (1-3) and it finally worked out. Excellent post!!! Congrats.
Return to “Generic”
