Adj inno spot moving head program?? Topic is solved
Djwesty
Post by Djwesty »
Hi guys so at mo I'm running 2x pilot 150 my new addition is 2x adj inno spots can't find program for freestyler any ideas peeps ?
Thanks all !
kittmaster
Commited FS Forum helper
FreeStyler Version: 3.6.2
Re: Adj inno spot moving head program??
Post by kittmaster »
If you don't see it, it doesn't exist, your going to have to create it, or someone will have to for you.
You should look at the DMX sheet of your light and compare it against another light from same brand and see if they line up in values, if they do, you can use the other light profile for now to get it working until a proper version can be released.
