I have 3 fixtures connected in my test set up, one PAR 56 LED, One laserworld ES 400 RGY and one American DJ Hypergem
When i use the blackout function only the PAR 56 goes out, and the other remain unaffected.
The channels are set correctly and everything else works as expected
What am i doing wrong?
Regards,
Marcus
Problem with blackout
- FreeStyler Version: 3.3.2
- Spirit
- FreeStyler Version: 3.5.9
Re: Problem with blackout
Hi
blckout depant on the Channels you use..
and FS looks at it in ONE order..
IF Fixture has Shutter, then Shutter CLOSED is used for Blackout.
IF Fixture Doesnt have Shutter, BUT intensitie channel, Then Intensitie MIN is used for Blackout
IF fixture doesnt have Shutter or Intensitie, BUT RGB channels, then RGB "0" is used for Blackout..
Ok thats sound logical, i suppose that you define this in the fixture file using the fixture editor then?
- Spirit
yes you need the FC to do this..
Thanks again, i did what you said and it works like a boss
+10
