Cue Multiselect help Topic is solved
drunkenmind
Post by drunkenmind »
Hi everyone
I'm having some problems running multiple cues at the same time. For one CUE I've got some moving heads which I programmed to go from down to up;
http://youtu.be/JE-N4YGieHg
Then I've got some LED parcans which change colour from red to blue on another CUE;
http://youtu.be/hwj_RsV2Os0
When I run them both together the LEDs flash on and off briefly rather than fading like they do in Video 2;
http://youtu.be/3baJY5JKiiI
I've ticked 'Cue multiselect always enabled' in the settings and on both separate CUE files I've put all of the other fixtures to 'Off' and the fixtures I am working with to 'Snap' as you can see from the attached photo (I forgot to take one for the red and blue fade CUE).
I'm probably doing something completely obvious wrong so hope somebody can point it out for me?
Thanks in advance
Re: Cue Multiselect help
oke and can you also explaine what the issue is what you have..
-what do you do?
-what do you expact?
drunkenmind
Hi Spirit
Thanks for the reply.
-what do you do?
I press play on both CUEs in the CUE list selecter
-what do you expect?
I expect both individual CUEs (video 1 and video 2 above) to both run at the same time
ahhh Yes..
No this is not how Freestyler works..
Only 1 Cuelist buttons can be Active at the time..
BUT all 20 SEQ from a CUElist can be playback at the same time..(IF multiselect is Enabled)
But i would take a look at the Submasters.
Load the par CUElist into Submaster 1 and load the MH Cuelist into Submaster2.
and playback both sequences..
