Flash lamps
stump77
FreeStyler Version: 3.5.4
I Use FreeStyler for: Theater
Flash lamps
Post by stump77 »
Is there an easy way to create a random flash sequence?
Nathanrs93
FreeStyler Version: None
Re: Flash lamps
Post by Nathanrs93 »
stump77 wrote:Is there an easy way to create a random flash sequence?
Hi
It all depends on what fixtures you have available to you and what you consider "easy" personally, due to someone else like myself thinking of easy in a different view.
Regards
Nathan
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Flash lamps
Post by buttza »
This is where my request to be able to create your own waves in the FX generator would come in handy. :)
Re: Flash lamps
you can just create a Easy Seq. and Enable the random option on the CUEwindow
