Is their a way to define the dance floor area or area for a moving head to use, within the application? So when the moving head is on sound active it will stay in a defined area?
Sent from my SM-N900T using Tapatalk
Define Dance Floor Topic is solved
- Kings
- Commited FS Forum helper
Re: Define Dance Floor
One of the features of FS is a pan/tilt adjustment that makes a moving head light only move within a certain (square) area. Great for defining a dance floor or stopping it lighting up unwanted areas. Check the set up options. It only works for preprogrammed chases so It won't work if your fixture is set to some sort of auto mode. Hopefully your fixtures have a STL mode as part of there DMX profile.
djkrazy
I Do have STL modes. How do I activate the pan/tilt square restrictions area? Thanks
- Kings
Preferences - pan/tilt resize
- Kings
djkrazy
Link says topic does not exist?
- djSupport
djkrazy probably because your on tapatalk, that's a wiki page you need to go to the browser...
