i would like to using Running Cues (Chases) in a Matrix ( LED or Suntrix, same problem) and also using this Plugins..
Sample : 6x6 PAr can's in a Matrix with Suntrix making their show.. , now i would switch the Effekt to an Self Programmed Chase in the Normal Cue selection, So i fade Out the Suntrix pluging an starting the cue..
The Problem is now : Suntrix sending always "zero" to the DMX channels.. and the Runnig cue starts Flashing and shit..
Is it possible to Stop Suntrix without Pressing The "X" in the right Corner?
Cues & SUN/LED-Trix for same Fixture
HooK
- FreeStyler Version: 3.5.4
And God said, c“Let there be light,” and there was light. ( Bible :Genesis 1.1 v 3)
Using: JMS USB Interface
