Master Intensity and Overwrite buttons
HooK
FreeStyler Version: 3.5.4
Post by HooK »
is there a way that the "Masterintensity" are also Control the Overwrite buttons?
Got many Par "Flash-Buttons" but a are all to bright! in different scenes
If i put the master 0n .. 50% the Overwrite Button ignorr that and sending 100% )
And God said, c“Let there be light,” and there was light. ( Bible :Genesis 1.1 v 3)
Using: JMS USB Interface
jdmyers
Re: Master Intensity and Overwrite buttons
Post by jdmyers »
You'll probably have to save a version for the intensity(s) you're trying to reach. I've found this to be a problem sometimes, but a bonus other times (running at 50% then being able to flash or highlight things at 100% can make a nice effect.). I have a few button pages with certain scenes saved at 100 on one page, 75, & 50% on two others, to try and match where I happen to be at on the master (which I control via MIDI controller) depending on venue & circumstances.
