Hi Everyone,
I bought a Numark Orbit MIDI controller in hopes of using it with Freestyler. I'm able to connect it to Freestyler (3.54) and when setting up the MIDI profile, I see appropriate MIDI channels / values change in the when assigning buttons to Freestyler functions.
I can't figure out why when all assignments are defined and confirmed committed, Freestyler won't respond to these commands. E.g. I have a few buttons setup on the Orbit to control sub master functions (up / down / stop / run) and nothing seems to respond. I suspect I'm missing something simple.
Numark Orbit MIDI Controller
- FreeStyler Version: 3.54
- FreeStyler Version: 3.5.9
Re: Numark Orbit MIDI Controller
I know it's been a while but I've just purchased a Numark Orbit and I'm having the exact same issue myself...
Freestyler obvouisly recognises it but it doesn't do anything once you exit out of setup!
Edit: I've just updated to 3.6.3 and it seems to be working however I need to double tap for example:
Override button 1 (set all lights to blue):
1st tap = lamp dimmer 100%
2nd tap = change colour to blue
3rd tap = nothing I can see
4th tap = lamp dimmer 0%
hmmm..
hmmm..
- FreeStyler Version: X2
I have the Orbit too... Sorry my English isn´t Good Enough to say why, but I think it´s not possible to use it for (Flash - ) Overrides (because Toggle/NoteOnOff). But normal Overrides are working on the Numark Orbit. Maybe you first try to control simple functions - like Blackout... And do some experiments with the "Note On/Off" function in the MIDI settings. I have activated it....
- FreeStyler Version: 2.96g
I also have the orbit. It works fine, but the only thing i had is that de led pad's doesn't have the colours that i have made in the orbit editor from numark.
The pads light up as black or white and not ass all the colours that i programmed.
Can U help of give me info please ?
