Console-style sliders?
djmt99
Just started using FS
FreeStyler Version: 3.5.4
Post by djmt99 »
I've checked the downloads and can't see to find anything quite like what I'm looking for. Yes yes, I know there are the faders in the upper right-hand corner, but those are just too small of a "throw"/range for some of my applications. Would it be possible to have a window with some long-throw sliders to better adjust and fine tune a range on a channel? It should also show the value.
djmt99
Re: Console-style sliders?
Post by djmt99 »
Hmm, I could've sworn I posted this in Ideas & Remarks. Please move, if possible.
no there isnt..
you can use TUI2 to have sliders that realy look like sliders..
or if you only like to have it to finetune the channel.
then the Latest Slider (Rightside) you drag can be finetuned with the + and - from the Numpad.
for laptop you need to use the "FN" key to acces the numpad.
