Hi folks,
Love Freestyler...use it all the time.  But, I've got a couple small issues that I think could be easily fixed:
A)  Let's say I have a tap trigger going from the previous song (I work with live bands.)  Then, let's say the next song starts.  Often, I try to pre-set the tap as best I can, but I never know exactly when they're gonna start, so often it is off a little.  Then, let's say when they start the song, I trigger a cuelist.  FS waits for the next tap trigger before it starts the cuelist, so I miss a few beats.  I think it would be better if FS, when I trigger a cuelist, just starts the cuelist right then and resets the tap-sequence (at the same speed I already set) and starts immediately.  I can get around this by triggering my cuelist and hitting tap almost immediately, but it's a pain in the butt.
B)  Most of my cuelists use multiple sequences (for instance, I have a ROYGBIV cuelist that has separate sequences for my moving heads and my back-lighting.)  The first time I run them, they stay in sync.  But, the second time I run them, they somehow have gotten out-of sync.  One starts at step 2 and the other starts at step 3, so therefore, they're no longer using the same colors on the same step.  It seems to me that when I start a cuelist, all of the sequences should start at step 1, but they don't do that.  Can we fix that please?
Thanks so much!
Kendell
									Two items, both regarding Tap timing
				kwelch007
 - FreeStyler Version: 3.5.6
 - I Use FreeStyler for: Band
