hello all!
i need some help with a fixture
a few days ago a created a new fixture file for my beamz mhl-108
everything runs fine exept for macro's (i will use them only as rgb wash)
but i cant change the intensity in my submaster windows
is there enyone who can help me out, if the fixture is completed it can be shared with other users
channel 6 is used for the intensity and strobe (in the file its called dimmer)
0 - 7 = off
8 - 134 is intensity (8 is full 134 is lowest)
135 - 239 = strobe (higher is faster)
240 - 255 = full on
again everything is working like open\close, intensity, strobe is limited at 237 (238 and 239 are way to fast)
but i cant change the intensity in the submaster window, did not have this problems with my other led parcans
i cant upload the fixture file for some reason
thanks in advance
cant change intensity in submaster window
scanlight
- Just started using FS
- FreeStyler Version: 3.4.8
- Spirit
- FreeStyler Version: 3.5.9
Re: cant change intensity in submaster window
hi yes indeed i need you fixture file.
but go to FILE-> and EXPORT the fixture file this way you get a .PFF file and it somekind of .zip file it also contence all the images
and a .pff should be upload to the forum
